Go Back   Garage Glamour™ > Videos > Professional Lighting Solutions
Video-statistics
Categories alltogether: 10
Videos alltogether: 286
Top-sender:
  1. rolandogomez (280)
  2. Navigator (2)
  3. Wrlss911Pro (1)
  4. rdavis (1)
Categories
Search videos
Best rated videos (same category)
Part 3 of 3: Rolando Gomez - Virgin Islands Workshop
Part 2 of 3: Rolando Gomez - Virgin Islands Workshop
Related videos
'I bounce' photo lesson 6: Greg Gorman shoots Matt at his LA Studio
'I bounce' photo lesson 1: Greg Gorman - I brought details down by substracting the light
'I bounce' photo lesson 5: Greg Gorman - fill light with white reflector
Random videos
Gwen Stefani Makeup
Gwen Stefani Makeup
Shaun Alexander- www.la-fashion-photographer.com
Model Fitness: Agustin's Partner Yoga Routine
Will It Blend? - Diamonds...as far as you know
StudioStyles Studiotip 1 - The Main Light
Video-details
Title StudioStyles Studiotip 1 - The Main Light
Category Professional Lighting Solutions
Rating
Date 01-26-2009, 09:40 AM
Description The main light is what we base all of our lighting on. In this StudioTip, Mike explains what the main light is, the difference between hard and soft light, and considerations when you are positioning the main light for various effects.
For more in depth training visit:
http://www.studiostyes.net
I have noticed that many new photographers tend to aim their main light source (this could be an umbrella, a softbox, etc...) directly at the subject. While this will definitely light the subject, it's certainly not the most flattering way to use your light source. In this post, I would like to introduce you to an idea called "feathering the main light".
By nature, your light source is typically brighter in the center and tends to fall off toward the edges. Therefore, by aiming your light source directly at the subject, it tends to create more specular highlights and can produce hot spots or can cause the highlights to become overexposed.
So next time, instead of just aiming the light right at your subject, try feathering the light. By this I simply mean to direct the light in front of your subject. You should be working with the edge of your light source and not the center of the light source. I will typically turn my soft box horizontally and have most of the light pass in from of the subject, and just work with the light from the back edge of my soft box. By working with the feathered position of the main light, it gives me a softer, more flattering light on my subject.
Not only is feathering the light much more flattering for my subjects, but it allows me to easily work with a reflector as my fill light - by reflecting the light passing in front of the subject into the shadow side of the subject. When working with a large soft box and feathering, this box acts as both the main light and the fill light ( a term referred to as wrap-around lighting). It also helps keep stray light off the background so I can control the brightness of the background through the use of a background light.
Have something you would like to see covered in next months Lighting tip? Post it here.
by mluter
Hoster YouTube int.
Code to embed
Views 4,262
Comments 0
Action [Report video]
Comments
There aren't any comments to this video!
Premium or Lifetime Members May Add Videos.
